Date/Time: Fri, 04 Apr 2025 13:15:44 +0000
Drawing tools
View Count: 344
[2023-01-04 01:53:44] |
User528524 - Posts: 9 |
Subject updated from 'New day not loading' to 'Drawing tools' -------------------------------------------------------------------------------- Hello on one of my chart when I use drawing tools it's fine when marking them out but when I click to lock in it dissapears do you no why this is and can you help resolve? Thanks |
[2023-01-04 19:45:09] |
Sierra_Chart Engineering - Posts: 19068 |
It might be a problem with the color of the Chart Drawing. What drawing tool are you using specifically? After using the tool, do you see the drawing listed in Tools >> Manage Chart Drawings Window? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
