Date/Time: Fri, 04 Apr 2025 13:39:01 +0000
Unknown server error
View Count: 352
[2023-01-03 21:39:31]
User767284 - Posts: 1
I get an unknown server error text when i try to log in. how do i fix that
[2023-01-04 18:05:13]
Sierra_Chart Engineering - Posts: 19068
We apologize for the delay. We are checking on this.
Make sure your Sierra Chart Account Name and Password are entered correctly on the Login window.
Date Time Of Last Edit: 2023-01-04 18:05:53
[2023-01-04 18:12:57]
We have reset your Sierra Chart charting and trading software password. It has been sent in a separate e-mail to your e-mail address.
If you did not receive it, let us know. Your e-mail provider may have filtered the message and placed it in a junk mail folder.
For complete Login instructions and help with possible Login problems, refer to:
Sierra Chart - Software Login Instructions
If you continue to have a problem logging in, then let us know and provide us with the *exact* error message you see after pressing the Login button.
