Date/Time: Fri, 04 Apr 2025 13:33:46 +0000
cant find it
View Count: 336
[2023-01-03 18:33:14] |
User562957 - Posts: 58 |
Hello supportteam, 1) how are those two called ? How can I make the background from black to white / gray 2) how can I reduce the amount of informations in this area as you can see it goes nearly more behind the middle of the chart. |
![]() Attachment Deleted. |
[2023-01-04 18:15:02] |
Sierra_Chart Engineering - Posts: 19068 |
1, 2. Refer to: Working With Charts: Region Data Line / Chart Header You can control whether the field text is reversed or not. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-04 18:15:43
