Date/Time: Fri, 04 Apr 2025 15:42:04 +0000
volume profile question
View Count: 342
[2023-01-03 18:06:55]
coachted - Posts: 389
is a volume profile effected by the type of chart it is on..ie PNF rRenko time chart?
[2023-01-04 22:50:34]
John - SC Support - Posts: 39157
The volume profile can be affected by the type of chart depending on the timeframe for your Volume Profile and how you have the chart setup to handle the bars. This is something you would need to look into for the particular bar type and Volume Profile timeframe you are using.
