Date/Time: Fri, 04 Apr 2025 15:35:42 +0000
Changing the color of candlestick wicks independently of candlestick body outline
View Count: 328
[2023-01-03 17:06:42] |
Jimmy K - Posts: 10 |
Hi.. I have looked through your support board and manual and I dont see to Change the color of candlestick wicks independently of candlestick body outline. IE: Red Body -Red Outline and White Wicks... Is there a way to accomplish this?
[2023-01-04 22:42:20] |
John - SC Support - Posts: 39157 |
There is not a way to do this. Just so you are aware, there is an option for Graphics Settings >> Other >> Color Candlestick High-Low Using the Outline Colors, so you can get the wicks to be the same as the outline. Refer to the following for this setting: Graphics Settings: Color Candlestick High-Low Using the Outline Colors (Global Settings >> Graphics Settings >> Other) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
