Date/Time: Fri, 04 Apr 2025 15:40:50 +0000
Add NASDAQ real-time Symbols
View Count: 337
[2023-01-03 16:26:39] |
User875201 - Posts: 1 |
Can you please add PAAS (Pan American Silver Corp) and CTRN (Citi Trends) to the real time data symbols available in the NASDAQ?
[2023-01-04 22:29:07] |
John - SC Support - Posts: 39157 |
You can do this by copying an existing symbol to create a new one for the particular stocks you want. But unless there is something specific that you are looking for in the symbols (like the Tick Size, or the Price Format) then there really is not a reason to create a symbol. You can get the data for these items by just typing in the symbol name on the Find Symbol page (e.g. PAAS-NQTV). Refer to the information on copying a symbol here: Global Symbol Settings: Duplicating Existing Settings for a Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
