Date/Time: Fri, 04 Apr 2025 13:23:15 +0000
Reconnecting Wait
View Count: 507
[2023-01-03 13:48:18] |
Jono_VWAP - Posts: 10 |
Hello, I was wondering if you can help I was just trading 1 hour ago, I had to pay $11.50 for CME. Data and everything was working before I restarted my PC, (1hr ago) and now in the data feed it says ‘Reconnect Wait’ with a yellow background, can you help I have tried to follow the content on the support board Date Time Of Last Edit: 2023-01-03 13:48:47
[2023-01-03 14:29:57] |
Sierra_Chart Engineering - Posts: 19068 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed: Select "File >> Disconnect" Select "File >> Connect to Data Feed" After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-03 15:11:12] |
Sorry it was issue with my WIFI Card… issue sorted ThankYou
