Date/Time: Fri, 04 Apr 2025 13:15:45 +0000
I'm sorry but I'm lost again...
View Count: 380
[2023-01-03 00:06:16]
User280059 - Posts: 14
I have paid the requested amount but now I have a 15 to 30 minute delayed SIM account which does not allow me to trade Ninja Trader live. Up to this point I have been able to trade Ninja Trade live but now I can no longer trade. So what is a poor guy supposed to do? I think I need to move to Stage 5 Brokerage and then I will no longer be in limbo. My Sierra Chart trades will be live and my Apex Trader Ninja Trader will be live. So what do you think I should do? I am patiently waiting for your reply. Thank you.
[2023-01-03 00:38:46]
Sierra_Chart Engineering - Posts: 19068
Does your Ninja trader account use CQG or Rithmic? Which one.
The reason you are not getting real-time data, and historical data in the case of when using an external Trading service (Rithmic, CQG, Interactive Brokers), from the CME Group of exchanges is that you activated the *Non-Professional* exchange fees. However, you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees.
Refer to the "Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges" section here:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
Rithmic paper trading or trading evaluator accounts are not considered a live funded futures trading account.
Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees:
If you do not have a funded trading account or one with a supported Trading service, then refer to this solution:
Easy Solution to CME Funded Trading Account Requirement
Consider the above solution to avoid this problem in the future.
Date Time Of Last Edit: 2023-01-03 00:39:16
[2023-01-03 01:38:59]
User717569 - Posts: 15
Hi, I've paid the amount to get live data, it was a Package 4 and when i was on sierra charts it shows delayed data. Can you please help me fix this issue? Thanks.
[2023-01-03 04:56:31]
Yes we are trying to help, but it is not very simple due to CME requirements.:
For your Ninja trader account does it use CQG or Rithmic?
[2023-01-03 10:47:22]
I don’t use ninja trader, but I don’t use neither of those you mentioned. I believe it’s teton order routing/stage 5.
[2023-01-03 16:04:29]
We will contact Stage 5 for you about this.
[2023-01-03 16:11:37]
At this time you should be getting the real-time data. If not restart Sierra Chart.
If there is any incomplete data in the charts:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
