Date/Time: Sat, 30 Nov 2024 01:48:08 +0000
Is it possible to have Large Volume Trade Ind. with a different tick size than the chart?
View Count: 283
[2023-01-02 20:30:57]
localman - Posts: 38
I am using the Large Volume Trade Indicator and was wondering if it is possible to have the LVTI based on a different amount of ticks than the chart?
i.e. I would like to set the LVTI to encompass 5 ticks while my 5 minute chart is set to Tick Size .25 (Chart Settings->Symbol Settings->Tick Size)
The end result would presumably be the same as if I was running a chart with a Tick Size of 1.25 while running LVTI.
Is this supported?
Thank you.
[2023-01-02 21:43:51]
Sierra_Chart Engineering - Posts: 17266
No this is not possible.
[2023-01-03 13:32:42]
OK good to know. Thank you for taking the time to reply.
