Date/Time: Fri, 04 Apr 2025 13:10:55 +0000
Execution in Primary vs Sub Instances Reliability
View Count: 396
[2023-01-02 20:11:00] |
User624595 - Posts: 243 |
Any differences in reliability/robustness of how everything works running trade execution through primary instance vs sub instances in our setup?
[2023-01-02 22:30:38] |
Sierra_Chart Engineering - Posts: 19068 |
No, we have tested this extensively . Trading should be just fine in a sub instance. Sometimes but rarely a user will report to us, minor latency issue from the sub instance but we have not been able to reproduce that. However, make sure you are on the latest version of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-02 22:30:55
[2023-01-03 20:06:50] |
Specifically we are using Denali while executing at IB. Have this and any similar issues been resolved? order modification problem
Date Time Of Last Edit: 2023-01-03 20:07:17
[2023-01-03 20:46:43] |
As long as you are using the correct symbols as they are provided for Interactive Brokers in File >> Find Symbol, you are not going to have an issue.
