Date/Time: Thu, 19 Sep 2024 21:50:53 +0000
Open Range Study
View Count: 1151
[2014-06-02 06:45:56] |
User96267 - Posts: 43 |
Dear SC Support-Team, is there a study that displays the open range of a day? I found nothing useful. Maybe I searched the wrong topics. Thanks in advance Max |
[2014-06-02 08:49:17] |
The study is: High/Low for Time Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-02 09:10:28] |
Fantastic! Thank you!
[2014-06-02 09:51:16] |
ganz - Posts: 1048 |
User96267 FYI: open range question (for users as well) |
[2014-06-02 10:00:01] |
Is it possible to extend the horizontal lines? E.g. I have an open range from 8am to 9am and want to extend the lines through the whole day? |
[2014-06-02 10:19:16] |
Use: High/Low for Time Period -Extended We forgot about the extended one and that is really what you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-02 10:39:19] |
No problem though. That works for me! Thank you for the great work! |
