Date/Time: Thu, 03 Apr 2025 20:42:27 +0000
Spreadsheet - Returning value of first non zero cell in a column
View Count: 480
[2023-01-01 23:35:28]
User589284 - Posts: 6
Hi.
In a Spreadsheet formula, I am trying to get the value of first non zero cell in a column (from top to bottom).
Tried this formula that works in Excel, but it doesn't work on the Sierra Spreadsheet: =INDEX(AB5:AB50,MATCH(TRUE,INDEX(AB5:AB50<>0,),0))
Could you kindly suggest an alternative formula to achieve that result?
Thank you
p.s. only raising as I could not find a solution on the support forum nor figure out from the Spreadsheet Functions page.
[2023-01-02 01:35:30]
Sawtooth - Posts: 4197
Use another Formula Column to get a TRUE when column AB has a value, like this e.g. in P3:
=AB3>0
Then use a formula like this:
=INDEX(AB3:AB50,MATCH(1,P3:P50,0),1)
But there is an easier way:
=MOSTRECENTNONZEROVALUE(AB3:AB50)
https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#MOSTRECENTNONZEROVALUE_Function
