Date/Time: Sun, 24 Nov 2024 16:50:38 +0000
jedit integration with Sierra charts & how to use it ?
View Count: 397
[2023-01-01 19:28:39] |
mbarbhaya - Posts: 37 |
Dear Support, Please help me with instruction on how I can have some better editor like jedit integration with Sierra charts & how to use it ? |
[2023-01-01 20:57:54] |
Sierra_Chart Engineering - Posts: 17156 |
We recommend using Notepad ++ now. We are not experiencing issues with it anymore. JEdit was something that we had used a long time ago. Not anymore. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-14 16:31:06] |
User389369 - Posts: 6 |
Hi, I recommend updating this support page as I went through the effort of getting JEdit setup - Text Editors
[2024-05-14 18:36:33] |
We will update that page. Perfectly fine to use JEdit. But we do not use it any longer.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-14 18:36:46
