Date/Time: Fri, 04 Apr 2025 15:38:11 +0000
in a case I use 2 real time feed
View Count: 451
[2023-01-01 18:32:10] |
User61576 - Posts: 445 |
can both of them be "Full CME Group (CME, CBOT, COMEX, NYMEX) for non-professional Trading accounts" and only 1 has "CME with Market Depth for non-professional Trading accounts" I see that I can select the number of live connections under "Number Of Systems (Computers)" but will I be able to set each with the correct feed as described above? |
[2023-01-03 14:38:46] |
I set the "number of systems" to 2 and tried to connect both locations and I am failing both connections are set to CQG WebAPI (trading) I am getting an error as only 1 data service is set(and 1 computer is disconnecting the other). can you pls help? Date Time Of Last Edit: 2023-01-03 15:07:24
[2023-01-03 15:54:04] |
Sierra_Chart Engineering - Posts: 19071 |
No definitely not: can both of them be "Full CME Group (CME, CBOT, COMEX, NYMEX) for non-professional Trading accounts"
and only 1 has "CME with Market Depth for non-professional Trading accounts" We cannot help with the connection issue to CQG. CQG only allows one connection. For multiple connections you must move to Teton order routing: Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-03 15:54:15
[2023-01-03 16:05:11] |
so I need to set my connections as follows: 1. cqgwebapi 2. SC data all service and both get real-time data from Denali(as i set 2 service in the data page) ? |
[2023-01-04 15:19:09] |
SC team, any update to my question pls? is "SC data all services" and "cqgwebapi" are the same based on denali ? or only cqgwebapi is with denali? |
[2023-01-04 18:51:47] |
Regarding post #4, yes you can do that and both connections will receive the real time Denali Data Feed. For more information, refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-04 18:58:08
[2023-01-04 19:14:05] |
what about my question in #1 can both of them (systems data connection) be "Full CME Group (CME, CBOT, COMEX, NYMEX) for non-professional Trading accounts" and only 1 has "CME with Market Depth for non-professional Trading accounts" ? |
[2023-01-04 19:43:50] |
Both systems will have access to the market data provided among both of those exchanges you have active.
[2023-01-05 10:00:49] |
i want 1 system to have only "full cme" and the other system to have "full cme" + "cme with market depth" how can this be done as i don't need depth data on my trading machine |
