Date/Time: Fri, 11 Apr 2025 21:19:59 +0000
Study Summary does not sort on text columns
View Count: 417
[2023-01-01 17:12:56] |
donnicky - Posts: 33 |
I have tried value columns and it works, but Name and Comment1 columns sorting does no work. Is it by design? Any way to work around to have symbols in the desired order?
[2023-01-02 04:20:05] |
Sierra_Chart Engineering - Posts: 19154 |
We will check on this.
[2023-01-10 21:46:38] |
This will be solved, in an upcoming release. Please allow about a week.
