Date/Time: Fri, 04 Apr 2025 13:36:30 +0000
Footprint Chart Combined With Dom
View Count: 1985
[2022-12-31 20:53:10]
Stav - Posts: 104
Hi John, Sierra Chart
Happy New Year to you all at Sierra Chart.
Question:- My trading style is shirt-term scalper and I was wondering is there is a way to overlay (or combine) my current 5 tick Renko footprint chart with my DOM?
Essentially what I am asking is that can I see my evolving 5 tick Renko bars moving up/down with the DOM for the same price levels? Rather than having my footprint and DOM as two separate studies alongside each other.
If not, I would be more than happy to see the total Bid Volume/Ask Volume traded on the Dom for each successive 5 tick Renko bar?
Many thanks.
Kind Regards
Stephen
[2023-01-03 07:54:00]
User135370 - Posts: 162
You just add Chart DOM to your Renko chart
Trade tab gives you that option
[2023-01-03 12:46:09]
Stav - Posts: 104
I'm not sure what you mean, sorry I need help (an idiots guide) I don't just want to add any DOM or the standard DOM that comes with Sierra Chart but my configured DOM and footprint.
Steps to achieve this would be helpful.
Please see my attached DOM and footprint.
Thank you for your reply, but I need the sequence of steps to achieve this.
Kind Regards
Stephen
imageESH23-CME[M] #9 2023-01-03 07_37_50.795.png / V - Attached On 2023-01-03 12:45:16 UTC - Size: 90.35 KB - 399 views
imageESH23-CME[M] Renko 5t #2 2023-01-03 07_34_13.860.png / V - Attached On 2023-01-03 12:45:26 UTC - Size: 78.92 KB - 342 views
[2023-01-03 14:09:43]
Yes go to trade tab
Click trading chart DOM on
Then customise it as you would a normal DOM through the customise chart/Trade DOM columns
[2023-01-03 14:39:35]
Stav - Posts: 104
Thanks for your reply. Yep I did that, added the columns I wanted but not able to change fonts and colors like my DOM.
How do I change fonts sizes and colors of DOM now attached to my footprint like my configured DOM with trade window?
Is it in Global settings?
Regards
Stephen
imageESH23-CME[M] Renko 5t #2 2023-01-03 09_35_40.846.png / V - Attached On 2023-01-03 14:38:43 UTC - Size: 73.64 KB - 195 views
imageESH23-CME[M] #9 2023-01-03 07_37_50.795.png / V - Attached On 2023-01-03 14:39:02 UTC - Size: 90.35 KB - 162 views
[2023-01-03 14:54:11]
Sierra_Chart Engineering - Posts: 19068
Refer to this page here:
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM
[2023-01-03 15:55:32]
That works too good luck
[2023-01-03 16:37:19]
Stav - Posts: 104
Hi Sierra Chart/ User135370
I'm able to change the font sizes with the DOM attached to footprint, but even though
I map 1-1 Chart Dom Fields with Trade DOM Fields settings, I am not able to get the new attached DOM with footprint to look like my standalone DOM, so not sure why?
Regards
Stephen
[2023-01-03 17:51:28]
Stav - Posts: 104
Hiya,
I think maybe because I am attaching the DOM with Footprint it doesn't allow me to change the background colours to my
standalone DOM that I created, most probably I'm wrong.
Using Trade> Customise Chart/Trade DOM Column, I have added the Current Traded Bid Volume / Current Traded Ask Volume onto my original constructed DOM and want to know if it is possible for these fields to refresh like the successive Renko bars, rather than just accumulating the bid/ask volumes? That way I wouldn't need to attach my DOM with footprint.
Sorry that I'm asking a lot.
Appreciate massively your help on this.
Kind Regards
Stephen
imageESH23-CME[M] #5 2023-01-03 12_50_55.572.png / V - Attached On 2023-01-03 17:51:16 UTC - Size: 148.59 KB - 243 views
