Date/Time: Thu, 19 Sep 2024 22:02:46 +0000
Package 5 question
View Count: 1856
[2014-06-01 18:09:39] |
George - Posts: 60 |
If I use Rithmic data with Sierra Chart Package 5, will I receive "tick" data for historical prices from SC, from the time the computer is turned off to the time it is turned back on and logged on to Rithmic?
[2014-06-01 21:59:01] |
Only if you are using Rithmic with Optimus Futures: http://www.sierrachart.com/index.php?l=doc/OptimusRithmic.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-01 21:59:15
