Date/Time: Thu, 03 Apr 2025 20:27:56 +0000
teton secondary instance is not allowing
View Count: 588
[2022-12-30 17:19:09]
mbarbhaya - Posts: 37
Dear Support, please help me wit this error ..
Connection error message from service: Teton CME Order Routing | Logon error received from server: Secondary instance is not allowing connections to this server | Date-Time: 2022-12-29 22:32:36
imageteton secondary instance is not allowing.png / V - Attached On 2022-12-30 17:18:41 UTC - Size: 8.11 KB - 105 views
[2022-12-30 18:06:55]
Sierra_Chart Engineering - Posts: 19064
It is possible for you to encounter that error message, if there is a connectivity issue to the Teton order routing server. However, there will be a retry to another alternate address and then eventually back to the primary address.
Follow the procedure here to reconnect if you are still not able to connect:
Let us know if you are still having issues.
Click OK on that message box showing that error to close it.
Date Time Of Last Edit: 2022-12-30 18:07:12
