Date/Time: Thu, 03 Apr 2025 20:37:22 +0000
How to sync 'Intraday Chart Session Times' with Dom 'DPL' for one instrument?
View Count: 444
[2022-12-30 17:18:57] |
User65931 - Posts: 18 |
How to sync 'Intraday Chart Session Times' with Dom 'DPL' for one instrument? I have a Time Zone setting: +9 Here are my Chart Settings [Session Times] Session Start Time: 19:00:00 Session End Time: 18:59:59 Use Evening Session: No Apply Intraday Session Times to Intraday Chart: Yes Here are my settings for Chart Settings [Trading] Order Fills Start Date (blank for all): it is blank Order Fills Start time (blank for all): 19:00:00 Start Times for Trades List: 19:00:00 Global Settings --> Symbol Settings (for the instrument) Session Start Time: 19:00:00 Session End Time: 18:59:59 Use Evening Session Times: no Based on the above entries I hoped that whatever profit/loss is shown in the DOM DPL would go to 0.00P at 19:00:00. (There is no trade in progress between 18:59:59 ~ 19:00:00) But it does not go to 0.00P at 19:00:00. It goes to 0.00P at 00:00:00 (midnight where I am). Please show me how to make DPL go to 0.00P at 19:00:00 each day and then continue to show DPL for that day's trading until 18:59:59 the next day. |
[2022-12-30 17:55:57] |
John - SC Support - Posts: 39148 |
Remove (make blank) the entry for Order Fills Start Time. Then set the option for Load Order Fills for Current Day Only to Yes (this is located on the same page within the Chart Settings as the Order Fills Start Time). Refer to the following for this setting: Chart Settings: Load Order Fills for Current Day Only (Chart >> Chart Settings >> Trading menu) This should do what you are wanting. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
