Date/Time: Wed, 09 Apr 2025 23:28:23 +0000
Chartbook file is not compatible
View Count: 429
[2022-12-30 12:30:04] |
N195 - Posts: 11 |
Hey I'm trying to open an old chartbook and the message log tells me: "The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. File C:\Users\..." Thanks! |
[2022-12-30 17:01:04] |
John - SC Support - Posts: 39249 |
Refer to the instructions here: Chartbooks (Workspaces): Opening Older Chartbooks For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-06 09:11:11] |
N195 - Posts: 11 |
I can see in the end of the section "Opening Older Chartbooks" that I can attach the chartbook here and you will convert it for me. I would like to do that instead of downgrade Sierra Charts and then upgrade it. I'm attaching my old chartbook in privet. Thanks a lot for this help! Noam |
[2023-01-06 16:38:45] |
Attached is your updated chartbook.
