Date/Time: Fri, 04 Apr 2025 13:20:24 +0000
Stop buy/sell order with different limit price than trigger?
View Count: 433
[2022-12-30 12:06:54] |
User166108 - Posts: 73 |
Imagine I want to buy a pullback after a breakout but don't want to sit around and manage the trade. The current price is 100, the breakout level is 120, and I think it will pull back to 110 after the breakout, at which point I'd like to buy. I want to put in a stop-buy order at 120, but the limit price for the entry is 110. I can do this natively with Interactive Brokers, but I can't find the equivalent functionality with SierraChart. Help would be appreciated to achieve the goal. Thank you. |
[2022-12-30 19:27:44] |
ondafringe - Posts: 320 |
Yes, you can do this in SC. You can use the "Triggered Limit" order type on the Trade Window. Date Time Of Last Edit: 2022-12-30 19:38:28
[2022-12-30 19:38:12] |
nice
[2023-01-03 22:41:14] |
Sierra_Chart Engineering - Posts: 19068 |
Yes use Triggered Limit: Order Types: Triggered Limit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-03 22:49:47] |
nice
