Date/Time: Thu, 03 Apr 2025 20:32:37 +0000
Is It possible to make a chart like this..
View Count: 593
[2022-12-30 10:23:37] |
User912175 - Posts: 9 |
hello im trying to figure out if it is possible to create a chart that looks like this on sierra This is a footprint chart from ninja trader. the green arrow is dispalying a regular candlestick the blue arrow is displaying cumulative delta for each price level in a histogram format and then the red arrow for volume profile with highlighted point of control is this possible to make a chart like this on sierra ? |
[2022-12-30 15:47:09] |
John - SC Support - Posts: 39148 |
Yes, you can it to look close to this. - To get the bar information to the left - use the Inputs for Open/Close Marker Style and Place Open Marker In and Place Close Marker In. Refer to the information starting here: Numbers Bars: Open and Close Marker Style - For the Cumulative Delta use the Numbers Bars Background Type of Ask Bid Difference Profile. Refer to the information here: Numbers Bars: Numbers Bars Background Types - To get the "regular" volume profile, use the Numbers Bars Background Type of Volume Profile in Column 2. - To highlight the Point of Control in the Volume Profile use the Input for Highlight Point of Control In and select Column 2. Refer to the following: Numbers Bars: Highlight Point Of Control In For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-30 15:47:35
