Date/Time: Thu, 03 Apr 2025 20:30:17 +0000
[Programming Help] - ACSIL Calculate Bar Duration in Seconds
View Count: 751
[2022-12-30 07:11:46]
TriStar Trading - Posts: 154
Can anyone help with ACSIL code to calculate the duration of the current price bar in seconds? I'm using range bars. Thanks in advance, Mike
[2022-12-30 12:33:14]
User431178 - Posts: 633
Take a look at sc.BaseDataEndDateTime and SCDateTimeSpan (in scdatetime.h).
ACSIL Interface Members - Variables and Arrays: sc.BaseDataEndDateTime[]
There is also the SCDateTime member function GetTimeInSeconds, so you could compare the start time in seconds vs. end time in seconds.
Working with the SCDateTime Variables and Values: GetTimeInSeconds()
[2022-12-31 18:57:41]
Here is how I did it after stealing some code here and there. :) Thanks.
//Set the configuration variables and defaults.
SCSubgraphRef BarSeconds = sc.Subgraph[0];
if (sc.SetDefaults)
//Set the configuration and defaults
sc.GraphName = "Bar Duration In Seconds;
sc.GraphRegion = 1; //Not Main graph region
sc.AutoLoop = 1;
sc.ValueFormat = 0;
//Define the Subgraphs
BarSeconds.Name = "Bar Seconds";
BarSeconds.DrawStyle = DRAWSTYLE_BAR;
BarSeconds.LineWidth = 2;
BarSeconds.PrimaryColor = RGB(128,128,128);
return;
SCDateTimeMS BarEndDateTime = sc.GetEndingDateTimeForBarIndex(sc.Index);
SCDateTimeMS ElapsedTime = static_cast<float>((BarEndDateTime - sc.BaseDateTimeIn[sc.Index] + SCDateTime::MICROSECONDS(1)).GetAsDouble());
BarSeconds[sc.Index] = ElapsedTime.GetTimeInSeconds();
Date Time Of Last Edit: 2022-12-31 18:58:30
[2023-01-01 01:14:34]
User183724 - Posts: 194
thx for posting this
