Date/Time: Thu, 03 Apr 2025 20:39:44 +0000
How do you change the axis size?
View Count: 446
[2022-12-29 20:11:43]
User154791 - Posts: 14
How do you change the axis size? I have moved over to a new PC and the chartbook axis have gone strange on some of the windows. I have attached a photo of what I mean, the left window has a normal sized axis I want, however the one on the right takes up far too much space.
Any help will be amazing.
imagephoto_2022-12-29_20-11-16.jpg / V - Attached On 2022-12-29 20:11:33 UTC - Size: 106.15 KB - 115 views
[2022-12-29 21:00:20]
John - SC Support - Posts: 39148
You can not change the width of the Price Ladder. It is set to automatically size to the width of the numbers that are displayed within it.
That being said, however, you should not have the situation you are showing in the chart on the right.
When we have seen this, it is because there was something that was taking up the space - such as the values for a study that was in another region. Please select Chart >> Recalculate and see if that resets the size. If not, then try Chart >> Reload and Recalculate.
If it still does not change after the above, then let us know.
