Date/Time: Sat, 26 Sep 2026 18:42:33 +0000
Delta chart
View Count: 1806
| [2014-06-01 12:16:48] |
| User78745 - Posts: 38 |
Dear all, Someone knows howw to set up a delta chart on a chart ? Cumulative delta is not what I am looking for. I am looking precisely the delta that you can find on a Numbers Bars Study. Thank you all for your prompt reply. Regards, |
| [2014-06-01 20:50:44] |
| Zosimus - Posts: 345 |
Are you looking for the Ask/Bid Volume difference Bars study ? If yes, it is documented here: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s291 |
| [2014-06-01 22:02:31] |
Delta means difference. So what do you want to calculate the difference of? We need more specifics. In Sierra Chart terminology, rarely do we use the term "Delta" because it is nonspecific in and of itself. The terms we use are much more specific to indicate the calculation method of a particular feature. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-01 22:03:55
| [2014-06-01 22:35:07] |
Dear, Yes, it's the difference between ASk vol & Bid Vol. regards, |
| [2014-06-01 22:56:49] |
You could use the following studies listed in Analysis >> Studies: Bid Volume Versus Ask Volume Ask/Bid Volume Difference Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-01 22:57:00
