Date/Time: Thu, 03 Apr 2025 20:30:17 +0000
Live data without trading. Non pro
View Count: 616
[2022-12-29 17:44:17]
sirmike95 - Posts: 2
If I only want live data with non pro fees. how do I obtain this? I have an IG/Tradovate account if that helps. Very confusing.
[2022-12-29 18:33:34]
John - SC Support - Posts: 39147
What are the exchanges for which you want the real-time data?
[2022-12-29 19:01:09]
CME and CBOT! Thanks!
[2022-12-29 19:33:53]
The CME Group does have a requirement that in order to get the real-time data at the non-professional pricing that you have a live, funded, futures trading account. The verification of this account is done by connecting your Sierra Chart to that trading account at least once a month. Refer to the following for more information:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
If Tradovate has you setup to use CQG for your order routing, then you can connect your Sierra Chart to that CQG account, although you may be charged to do so (you will need to check this with Tradovate). If you go this route, then follow the instructions at the following link to connect to your CQG account:
CQG Trading Platform Service: Setup Instructions
Another option that is a single outlay of $100 that will sit in the account is outlined at the following link:
Easy Solution to CME Funded Trading Account Requirement
Once you have worked out the above, then you can setup the Denali Exchange Data Feed by following the instructions at the following link:
