Date/Time: Thu, 03 Apr 2025 20:25:37 +0000
Add Extenssion Multipliers to High / Low for Time period - Extended Study
View Count: 339
[2022-12-28 22:54:26] |
User215984 - Posts: 24 |
Hi, Is there anyway to add extension multipliers like the extension multipliers from the Initial Balance study to the High / Low Time period - Extended study? Thanks! |
[2022-12-29 12:26:13] |
mlt124000 - Posts: 34 |
+1
[2022-12-29 17:23:05] |
John - SC Support - Posts: 39147 |
Use the Study Subgraph Multiply study set to the High or Low from the High/Low for Time Period study. Refer to the following: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
