Date/Time: Thu, 03 Apr 2025 20:25:38 +0000
12h and 24h graph
View Count: 716
[2022-12-28 19:03:40] |
chenS - Posts: 2 |
hi, i tried to do 12h and 24h graph and it's not working broker tried to help me too without successes |
[2022-12-28 19:53:08] |
John - SC Support - Posts: 39147 |
First off, our servers are showing that you are connected to our Teton Order Routing Service, but you are not setup to get any real-time data. Make sure you activate the exchange(s) you want at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges As to setting a chart to 12 hours or 24 hours, start by opening a chart for the symbol you want by selecting File >> Find Symbol, finding the symbol you want and then selecting Open Intraday Chart. This will open a 1 minute chart by default. Then go to Chart >> Chart Settings and select the page for Bar Period at the top. Then in the Setting (Days - Minutes - Seconds) field enter 0-720-0 for a 12 hour chart or 0-1440-0 for a 24 hour (intraday) chart. Select OK to close the window and the chart will update to the proper timeframe. For more information on how to change bar periods, refer to the following: Changing Chart Bars Period For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-30 06:37:43] |
chenS - Posts: 2 |
how can i add this to the shortcut control bar so i won't need to write this code every time?
[2022-12-30 14:41:42] |
Follow these instructions: Control Bar: Custom Buttons for Intraday Chart Bar Period For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
