Date/Time: Thu, 19 Sep 2024 21:41:41 +0000
Point and Figure chart close is incorrect
View Count: 1078
[2014-05-31 14:01:10] |
OneMoreTick - Posts: 79 |
The close on the Sierra point and figure charts is incorrect. It always shows as the high or low of the bar which is impossible.
[2014-05-31 21:34:03] |
Refer to the documentation here for this study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s140 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
