Date/Time: Sat, 05 Apr 2025 05:41:59 +0000
Base standard Package 26 USD/month
View Count: 461
[2022-12-28 17:06:06] |
Anders Nygård - Posts: 1 |
Hi I;m intersted in the Package as subject I have a few questionsto If I update to package as subject in main control and make the payment I dont want the package that are listed there before will they automatically be deleted Will I be able to have acces to Futures -CBOT and -CME with standard package Can I use a set up file from G7FX-education chart to get the same setup on charts as in my education Best reegards |
[2022-12-28 18:45:24] |
John - SC Support - Posts: 39172 |
If I update to package as subject in main control and make the payment I dont want the package that are listed there before will they automatically be deleted We are not quite sure what you are asking here, but we think you are asking if you change your package, what happens? When you change your package, we adjust the amount of Usage Time left based on the costs of the old and new package. You do not need to pay any additional fees, only the Usage Time changes. So if you go to a more expensive package, your available Usage Time will go down, and vice versa. Will I be able to have acces to Futures -CBOT and -CME with standard package
On the Base packages you have access to the Delayed Streaming Data For the CME Group, but you do not have access to the real-time data. If you want real-time data, then you will need to be on one of the Integrated Packages. Also, keep in mind the CME Group requirement that you have a live, funded, futures trading account in order to qualify for the non-professional exchange fees. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Can I use a set up file from G7FX-education chart to get the same setup on charts as in my education
We do not know, as we do not know what studies G7FX uses. Basically, the difference between the Standard and the Advanced packages are the following studies: - TPO - Numbers Bars - Numbers Bars Calculated Values Therefore, if you need any of the above studies, then you will need to be on the Advanced package. Refer to the following for all the information on the different packages: Description of Service Packages and Pricing: Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-28 18:47:42
