Date/Time: Thu, 03 Apr 2025 19:32:26 +0000
Equivolume Bars LEFT of Volume Profile Numbers Bars?
View Count: 424
[2022-12-28 15:09:20]
TopGunTrader - Posts: 191
Is there a way to display equivolume bars left of volume profile numbers bars? I think it would require a shift for them left and shift numbers bars right.
imageCapture.PNG / V - Attached On 2022-12-28 15:09:11 UTC - Size: 108.78 KB - 130 views
[2022-12-28 17:24:43]
John - SC Support - Posts: 39147
There is not a way to do this. The built-in options for displaying bar data within the Numbers Bars study itself does not have an option for a Candlestick that is offset to one side. There are other options, such as "Open/Close Boxes" that are available. Refer to the following:
Numbers Bars: Open and Close Marker Style
And when using the Study/Price Overlay, it is going to put the bar in the center of the time point for that bar area, which is what you are seeing now, and there is not a way to offset it.
[2022-12-28 20:47:50]
I spent so much time looking for this option figured this was case thanks for fast reply.
