Date/Time: Thu, 03 Apr 2025 19:31:35 +0000
Connecting to Live Data and Turning Sim Account off
View Count: 369
[2022-12-28 14:58:11]
User278794 - Posts: 13
I currently am using three monitors and each one is using a different sub instance. My main monitor (Middle) or Sub Instance #1 has live data, but Sub Instance #2 (Left Monitor) does NOT have live data, and same with my Sub Instance #3 (Right Monitor), it also does not have live data. I have looked all over to find something but can't. So wanted to see what I needed to do there. I'm using the Teton Order Routing. And the last thing is, I'm trying to turn off Sim mode, where is that found, Global Setting? Thanks in advance.
[2022-12-28 15:14:25]
So I figured out the data issue, now I just need to turn off the simulation of the account.
[2022-12-28 17:26:43]
John - SC Support - Posts: 39147
Turning off Simulation Mode should not make any difference to your getting data or not in the Sub-Instances. As long as you have the correct symbols in the Sub-Instances, then you should get the data into those sub-instances.
If everything is good now, then it is probably not worth prodding, but if you have issues later - let us know.
