Date/Time: Thu, 03 Apr 2025 19:32:26 +0000
C++ function to change the title bar name of a chart
View Count: 380
[2022-12-28 07:53:27] |
User61576 - Posts: 445 |
I want to change the name of the title bar of a chart using C++ code ( Which can be done manually using the option present in the chart settings ). Is there any function for the same?
[2022-12-28 16:22:20] |
John - SC Support - Posts: 39147 |
Refer to the following: ACSIL Interface Members - Variables and Arrays: sc.CustomChartTitleBarName For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
