Date/Time: Thu, 03 Apr 2025 19:31:33 +0000
Bars being drawn with edges at middle of each tick
View Count: 387
[2022-12-27 19:09:02]
User820791 - Posts: 15
Hello.
Is possible to make the bars/candles being fully drawn within each tick move like Jigsaw Auction Vista?
I've attached two images for further clarification.
Thank you.
Date Time Of Last Edit: 2022-12-27 21:01:26
imagemiddle.png / V - Attached On 2022-12-27 19:05:51 UTC - Size: 35.13 KB - 106 views
imagejigsaw.png / V - Attached On 2022-12-27 19:05:57 UTC - Size: 31.17 KB - 104 views
[2022-12-27 22:39:41]
John - SC Support - Posts: 39147
You can get this effect using the Numbers Bars study. Just do not display any numbers and set the following:
- Column 1 Numbers Bars Text: None
- Column 1 Background Type: Full Background
- Column 1 Background Coloring Method: Based on Above, At, or Below Last
Set other options as desired.
If you are scaled in to the view, then you may be able to see the separation of the price per tick. But this is going to be very dependent on the view.
[2022-12-28 08:37:44]
Thank you! It looks beautiful.
