Date/Time: Sat, 30 Nov 2024 02:55:28 +0000
Incoming webhook to generate study alert
View Count: 406
[2022-12-27 17:57:02] |
User375267 - Posts: 3 |
Hello, do Sierra Chart studies support using incoming webhooks to generate an SC study alert? Thank you for the help! |
[2022-12-27 22:24:32] |
We do not have support for specific webhooks, but you can program what you want through our study interface. If you are not already familiar with it, then refer to the following: Advanced Custom Study Interface and Language (ACSIL): Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
