Date/Time: Thu, 03 Apr 2025 20:25:38 +0000
COT.CPP cant compile
View Count: 746
[2022-12-27 15:12:04] |
blackcobra777 - Posts: 28 |
hye i want to tell you that i cant compile cot.cpp it says termiante idont why, do you have already compile .dll study?? or is there any thing i can do?
[2022-12-27 16:14:55] |
Sierra_Chart Engineering - Posts: 19064 |
Provide us the file so we can test this. Instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-27 16:52:11] |
see i attached it check it if you are able to compile coz i cant
[2022-12-29 03:13:32] |
ForgivingComputers.com - Posts: 1033 |
It will compile if you remove this line: #include "scstudyfunctions.h"
[2022-12-29 11:25:29] |
it is compile but now i cant use it shows nothing and sys cot report stud### quandle api key needed etc? what is this how can set all this to show cot and work it ? i attachted the screenshot too you check it and help to get through this thanks..
[2022-12-29 20:40:28] |
According to the Message Log, you need a Quandle API key. A quick search locates this site: https://rapidapi.com/zakutynsky/api/Quandl/details
[2022-12-29 23:03:04] |
sTILL CANT SHOW ANYTHING IDK WHY , See the readon i attached a two screenshot again, one is the log report says loding data but cant show anything other is settings of cot may be i i did it wrong check it plz and help me to see this..
[2022-12-29 23:28:51] |
User431178 - Posts: 633 |
COT data has one data point per week, try looking at it on a weekly chart instead.
[2022-12-30 00:10:22] |
yeah it works thanks
