Date/Time: Thu, 03 Apr 2025 19:32:26 +0000
[User Discussion] - price gaps/imbalance
View Count: 677
[2022-12-27 14:44:10] |
User246553 - Posts: 33 |
Hello, i would like to know if there is a study or a way that would show price gaps, like in the picture. i know there are a bunch of users that would want this to be displayed on their charts. https://www.sierrachart.com/image.php?Image=1672152187742.png |
[2022-12-27 20:51:01] |
John - SC Support - Posts: 39147 |
Refer to the following study: Extend Bar Gap Until Future Intersection For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-28 08:03:23] |
thx! BUT it shows the gap with a line and not with a rectangle showing how big is the gap, i tried to use several draw style types but it was always a line and is there a way to automatically extend the line even after a future intersection?
[2022-12-28 16:31:04] |
You can modify the study to have it do what you want. The source code is in the Studies5.cpp file in the ACS_Source folder under your main Sierra Chart installation folder. This is not something that we can get to any time soon, as we just have a lot of other priorities at the moment. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-28 16:56:21] |
ok, i understand, do you have a recommendation to whom or where i could contact someone that could help with this? as i don't have coding skills myself.
[2022-12-28 18:09:00] |
Refer to the following: List of Third Party Sierra Chart Study and System Programmers You may also get responses to this posting. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
