Date/Time: Sat, 30 Nov 2024 02:51:09 +0000
Thank you for Number Bars update - Quick Question - Pic attached
View Count: 382
[2022-12-26 23:19:14]
HeyUgly - Posts: 247
so far diagonal delta works fantastic, thank you very much for adding
Possibly for next update could we have a color option? like my own study i have circled in the attached picture?
Just to identify 2 diff color Texts for + and -? a simple red/green?
Thats it! everything working great! Thank You again!!!!
I tried the Column 2 text coloring method , but could not find the new option. everything else is fantastic!
one other question, I notice when you add a second column in the number bars study, it moves the candlestick overlay to outside the main 1st column, is that normal? or is there a setting for that?
Date Time Of Last Edit: 2022-12-26 23:28:40
imageCapture.PNG / V - Attached On 2022-12-26 23:18:56 UTC - Size: 15.49 KB - 98 views
[2022-12-27 20:07:30]
John - SC Support - Posts: 36350
If you just want 2 colors, then set the colors for the Range 3 Up/Down to the two colors you want. Then set your Percent Compare Thresholds or Actual Value Thresholds to "0, 0, 0". This will force all colors to be the Range 3 Up/Down colors.
Which option is this? All the Text Coloring options are the same between Column 1, 2, and 3, so we are not sure what is not showing up properly.
If you are using the Study/Price Overlay to get your candlestick displayed in the Numbers Bars (as opposed to the options within Numbers Bars - Place Open/Close Marker Boxes In), then what you are seeing is normal and there is not a setting for it. The Study/Price Overlay is just placing the bar in the middle of the range for the bar, and when you have more than 1 column that middle is moved to between the two columns. There is no "Fix" for this.[/quote]
Date Time Of Last Edit: 2022-12-27 20:07:51
