Date/Time: Sat, 30 Nov 2024 02:46:39 +0000
Help with Custom Symbol
View Count: 315
[2022-12-26 22:57:50]
rwilliams1 - Posts: 346
Hello I am using the custom symbol function and I'm trying to use a formula to invert a symbol (JPY) but for some reason can't seem to pull up the historical data for it. As you can see in the screenshot, the original symbol (top chart) loads fine with all of the historical data, but when I create a custom formula to invert the symbol, it only pulls up the current day real time data (bottom chart). I've been trying for three days to pull up historical data for the custom symbol but I've had no luck. Any help is appreciated.
imageJPY Inverted Symbol.png / V - Attached On 2022-12-26 22:53:55 UTC - Size: 57.97 KB - 78 views
[2022-12-28 00:17:56]
Sierra_Chart Engineering - Posts: 17267
We definitely cannot help with issues involving Interactive Brokers historical data.
Although refer to step 11 here:
Custom Calculated Symbols: Instructions
Date Time Of Last Edit: 2022-12-28 00:20:29
