Date/Time: Fri, 04 Apr 2025 17:34:10 +0000
Graphic Settings issue.
View Count: 645
[2022-12-26 20:32:41] |
User280673 - Posts: 27 |
I recently added a 4k monitor to my setup. I am running that and some other 1080p monitors. However, when I rebooted Sierra I noticed all the graphics settings are messed up. It looks blurry on the 1080p monitors and clear on the 4k. Also, the text is all wrong sizing and it varies from monitor to monitor. I realize there would be discrepancies due to the monitors having different resolutions however all my other programs are able to adjust without issue. I am confused about why it is so variable across monitors. I have adjusted the font settings and sizing but it just does not look good compared to what it looked like before. Are there any solutions to this issue? Thank you. |
[2022-12-27 05:48:58] |
Sierra_Chart Engineering - Posts: 19071 |
Also, the text is all wrong sizing and it varies from monitor to monitor. You can adjust the sizing of the text. Refer to:Graphics Settings: Adjusting Graphics Settings and Fonts for High DPI Displays It is also possible to change the text size for individual charts. So you can use larger text for the charts on the 4K monitor. Do you have the Use OpenGL option enabled within Sierra Chart do you know? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-27 05:49:06
[2022-12-27 13:17:13] |
Yes, I have OpenGL enabled.
[2022-12-28 00:22:30] |
See if there is any change in your issues when not using OpenGL. This is all the help we can provide.
