Date/Time: Sat, 30 Nov 2024 02:30:24 +0000
Historical Charts VbP not showing correctly
View Count: 399
[2022-12-26 16:43:35]
pete3m - Posts: 15
I've gone through the documentation and adjusted settings in the VbP study, as well as chart settings, but cannot establish why the volume at price looks so chunky on the weekly timeframe. How is the study adjusted so it shows properly? Thank you
https://www.sierrachart.com/image.php?Image=1672072791425.png
[2022-12-26 22:19:44]
pete3m - Posts: 15
Conversely, I have no problem on an intraday TF vis-a-vis volume by price. This is similar to what I would like to achieve in a historical chart.
https://www.sierrachart.com/image.php?Image=1672093110989.png
[2022-12-27 19:53:11]
John - SC Support - Posts: 36350
In part it relates to the information here:
Volume By Price Study: How Volume by Price is Calculated for Historical Daily and Higher Timeframe Charts
Use Intraday data and you will want to increase the Ticks Per Volume Bar setting:
Volume By Price Study: Ticks Per Volume Bar
