Date/Time: Sat, 30 Nov 2024 02:35:07 +0000
couleurs
View Count: 330
[2022-12-26 08:57:28]
User220939 - Posts: 36
Bonjour,
dans numbers bars, je voudrais mettre le code couleur suivant:
de 0 a 10 contrats acheteurs: blanc
de 11 a 20 contrats acheteurs: bleu
de 21 a 30 contrats acheteurs: rose
31 contrats et plus: vert
et pareil pour les vendeurs mais avec des couleurs différentes.
pouvez vous me dire comme faire?
Merci
[2022-12-27 19:37:16]
John - SC Support - Posts: 36350
From Google Translate:
in numbers bars I would like to put the following color code:
from 0 to 10 buyer contracts: white
from 11 to 20 buyer contracts: blue
from 21 to 30 buyer contracts: pink
31 contracts and more: green
and the same for sellers but with different colors.
can you tell me how to do it?
Thank you
To do this set the following options:
- Column 1 Numbers Bars Text: Bid Vol x Ask Vol
- Column 1 Background Type: Ask/Bid Volume Split Profile
- Column 1 Background Coloring Method: Based on Volume - Actual
- Column 1 Range 0 Down Color: White
- Column 1 Range 1 Down Color: Blue
- Column 1 Range 2 Down Color: Pink
- Column 1 Range 3 Down Color: Green
- Column 1 Actual Volume Compare Thresholds: 10, 20, 30
Other settings as you need/want them.
