Date/Time: Sat, 30 Nov 2024 02:33:54 +0000
Enabling Price on drawing tools/studies
View Count: 401
[2022-12-24 13:31:21] |
User711174 - Posts: 1 |
Hello, I've dug through previous support requests and answers but am still stuck. I just need price highlighted for drawings but can't seem to find the option. in a previous post user was told to go to drawing properties and enable price under labels tab. i don't have this option on my labels tab? |
sierra.PNG / V - Attached On 2022-12-24 13:30:45 UTC - Size: 18.88 KB - 84 views |
[2022-12-27 17:39:52] |
Not all drawings have the "Price" available as a display option. The only ones that do are those that are Horizontal, so they are associated with a specific price. The Line drawing, for instance, is not specifically horizontal, so the Price is not an option. But, the "Horizontal Line" drawing, for example, does have a Price option. The Line drawing, and most other drawings, do have a Text option, which you can add to the drawing after it has been drawn by right-clicking on the drawing and then selecting "Modify Text". The settings within the Configuration/Properties then apply to that text (such as "Opaque Label Background" and the Vertical and Horizontal placement). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
