Date/Time: Sat, 30 Nov 2024 02:34:26 +0000
Numbers Bars + VbP
View Count: 573
[2022-12-23 20:18:16] |
rondawes - Posts: 39 |
I'd like to have a Numbers Bar chart with a Volume Profile for each bar. I can do that, but the Volume Profile either overlays the numbers in the Numbers Bar (if aligned left) or the numbers in the previous Number Bar (if aligned right). I'd like empty space for the volume profile so that it does not interfere with the Numbers Bar. Possible? Thanks
[2022-12-23 20:24:54] |
Yes, you can do this using 2 columns for the Numbers Bars. In the first column turn on the Numbers display as you want it, then in the second column do not display any numbers, but turn on the profile as you want it. Here are the exact settings to get you started: - Column 1 Numbers Bars Text: Volume - Column 1 Background Coloring Method: None - Column 2 Numbers Bars Text: No Text - Column 2 Background Type: Volume Profile For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-23 21:37:14] |
Thanks John, I had the numbers bars set up like I wanted. Just needed to figure how to add the volume profile to the bar. I'm constantly pleased by the things that SC can do that cost extra addons in that "NT" product. It's all a matter of understanding the product. Thanks for your patience with our questions and have a Merry Christmas!
