Date/Time: Sat, 30 Nov 2024 02:47:31 +0000
ChartDOM not showing the Price Columns
View Count: 394
[2022-12-23 13:19:05]
User513390 - Posts: 49
Dears Friends,
On the TradingDOM, i can see my Price Columns but on my ChartDOM it is not showing.
Can you help please
Rodney
imageScreenshot 2022-12-23 at 13.57.14.png / V - Attached On 2022-12-23 13:16:12 UTC - Size: 281.98 KB - 88 views
[2022-12-23 14:50:35]
Sierra_Chart Engineering - Posts: 17267
Not sure about this. We would have to check the settings on that. Provide that particular chart by following these instructions:
[2022-12-25 07:27:20]
Dear Support Team,
Fist or all Happy Xmas.
I have followed the requested and posted the Chartbook with Still the ChartDOM not showing the price column
Thanks for your guidance,
Rodney
attachmentDOM not showing Price Colums.Cht - Attached On 2022-12-25 07:26:01 UTC - Size: 4.91 KB - 92 views
[2022-12-27 18:02:19]
John - SC Support - Posts: 36350
This chart has the setting for Scale Settings >> Scale Increment set to 0.25. Therefore the numbers do display, but they are fairly far apart. You will want to adjust that value to something more appropriate for this chart, or set it to zero (0) to use the automatic increment for the price scale. Refer to the following:
Chart Scale and Scale Adjusting: Scale Increment (Scale Settings)
