Date/Time: Thu, 19 Sep 2024 21:40:10 +0000
$tick access
View Count: 1129
[2014-05-30 17:26:37] |
User19148 - Posts: 1 |
I'm trying to add the $tick to one of my charts, but it says that it is not recognized. Is it avaialable and how do I add it to a chart? I'm interested in historical and real time. Thanks. |
[2014-05-30 17:35:16] |
This is an old symbol. There is a new market statistics data feed you need to use. Follow the instructions here: http://www.sierrachart.com/index.php?l=doc/SCMarketStatistics.php You need to update Sierra Chart with Help >> Download Current Version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
