Date/Time: Sat, 30 Nov 2024 02:39:21 +0000
Need Clarification on data feeds
View Count: 382
[2022-12-23 03:58:59]
ramsoft2003 - Posts: 6
I have two questions
  1. I recently connected my live trading account with SC and my data shows as delayed. is it because I don't have an active CME group's real time data feed?
  2. I also want real time NYSE tick data. So which data feed package covers this? NASDAQ total view or Nasdaq basic or is it covered within CME 4 pack bundle?
[2022-12-23 15:27:56]
John - SC Support - Posts: 36350
1. You are correct, you do not have any exchanges active, therefore you will not get the real-time data, even though you have satisfied the non-professional requirement of having a live, funded, futures trading account for the CME Group.
2. We assume you are wanting the Market Statistics for the NYSE Tick (TICK-NYSE). This is available at no cost as part of any Sierra Chart package. Refer to the information here:
Sierra Chart Market Statistics
If you are looking for something else, please let us know what it is and we can point you in the right direction.
[2022-12-23 15:48:05]
Thanks for the quick response. Yes my second question was about NYSE tick and I will use market statistics.
I have another question on having real time feed of ETF sector such as SPDR XBI, XFI from Nasdaq total view. I saw two packages one for $15 and another for $85. What’s the difference between these two packages and my requirement is to check the real time market correlation between ETF sectors and CME futures as I trade in futures market only. So Which one should I purchase to have real time data for these symbols?
Date Time Of Last Edit: 2022-12-23 15:48:32
[2022-12-23 18:06:56]
The difference between those two options is whether you are a Professional trader or not. If the exchanges consider you a professional trader, then you would need to use the Professional option, otherwise you would use the Non-Professional option (the cheaper one).
There is no difference with regards to the data between the options.
