Date/Time: Thu, 03 Apr 2025 01:20:52 +0000
Initial Balance Study
View Count: 365
[2022-12-22 21:14:06] |
coachted - Posts: 388 |
I dont understand why the initial balance on my PNF chart didnt match my TPO chart of volume charts...it is not just me but a buddy of mine that had the same issue...can you please advise????
[2022-12-22 21:16:07] |
there is definitley something wrong because even when i try to use hi/low for time period with 9:30:00 -10:29:59 the hi and low are wrong....
[2022-12-22 21:48:18] |
John - SC Support - Posts: 39122 |
A PnF chart is not time-based so unless you happen to have bars that start right at the start time and end at exactly the end time, you simply will not be able to make the comparisons you are attempting.
[2022-12-22 21:52:08] |
ok thanks
