Date/Time: Thu, 19 Sep 2024 22:04:51 +0000
Trade Activity Log
View Count: 1307
[2014-05-30 17:09:41] |
User85629 - Posts: 11 |
Is it possible to get the "Trade Activity Log" on the Trade menu to populate for a Demo Acct?
[2014-05-30 17:38:31] |
Yes. What Trading service are you using Sierra Chart with?
[2014-05-30 18:20:23] |
Infinity AT
[2014-05-30 21:35:04] |
What is Global Settings >> Data/Trade Service Settings >> Connection Type set to?
[2014-05-30 22:22:35] |
Connection Type is: Demo See screen shot that I assume got attached. Date Time Of Last Edit: 2014-05-30 23:06:35
Private File |
[2014-05-30 23:20:02] |
Therefore, any trading activity you perform from the TransAct software should be logged. And also Sierra Chart Trading activity will be logged. Make sure you have the correct settings at the top of the Trade Activity log. In the list of account select All Accounts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-31 01:49:07] |
If it did get logged into the trade activity log I wouldn't be writing you. I had over 40 trades today for a profit of $2,900 and not one trade got logged. I can't seem to get the Edit Attached Files button to respond otherwise I would send you a .jpg of the empty Trade Activity Log.
[2014-05-31 01:51:10] |
The limited version of the trade activity shows up in the TransAct log, but nothing shows up in the Sierra Chart Trade Activity Log.
[2014-06-02 05:52:25] |
If the orders are not entered from Sierra Chart, then we cannot help with this. We have no ability to control whether or not Sierra Chart will receive order data from the server for orders entered outside of Sierra Chart. You will need to contact TransAct support for help with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-02 12:06:17] |
Some of the orders were entered on your charts and some on the Infinity AT DOM. Transact said talk to you because they were only responsible for their platform which works and not for what shows up in your charts. Do the charts have a separate DOM from the AT platform? |
[2014-06-02 15:29:45] |
Trade Orders & Positions populates, but the Trade Activity Log zilch nada. Is that because it is on a demo setup?
[2014-06-02 16:08:59] |
What are the settings you have at the top of the Trade >> Trade Activity Log? What symbol are you trading from Sierra Chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-02 16:43:04] |
So sorry, didn't realize the blank box in the center had a drop down for each of the contracts I'm trading. Works just fine when I put in All Symbols or the contract. Wonder why it showed blank when I started it up?? Oh well, it works now . . . THANKS.
[2014-06-02 16:54:52] |
Here are the instructions to use the Trade Activity Log: http://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
