Date/Time: Thu, 03 Apr 2025 01:17:01 +0000
Max Delta does not have the right background colouring
View Count: 421
[2022-12-22 19:05:50]
User822688 - Posts: 4
I'm using the Numbers Bars Calculated Values study and using coloured text and background based on +/-. The Max Delta value can hit a number of "-1" when there has been no positive delta. When this happens, the background colour uses the Range 3 Down Colour as I presume it's the lowest possible value.
There are two minor issues that I have with this. One, I'd like to use NBCV with no background colouring unless there is major movement, utilizing the difference colouring for ranges up/down. It happens quite frequently that the Max Delta value is -1, so it actually uses the Range 3 Down colour quite often. Would it not make more sense to have the lowest value as 0?
The second minor issue is that the Min Delta actually does the same, but opposite. And this value actually does not use the Range 3 Up Colour when it happens as shown in the screenshot.
imageimage_2022-12-22_194600328.png / V - Attached On 2022-12-22 18:46:00 UTC - Size: 5.83 KB - 113 views
[2022-12-22 20:18:57]
John - SC Support - Posts: 39122
Can you please attach a chartbook with that chart in it for us to take a look. There are too many Inputs for the Numbers Bars Calculated Values, so we need to see how you have it setup to understand what is occurring. Follow these instructions to get us the chartbook:
[2022-12-22 20:37:29]
Here is my chartbook attached.
attachmentNBCV.cht - Attached On 2022-12-22 20:37:20 UTC - Size: 5.87 KB - 224 views
[2022-12-22 21:15:01]
The fact that the value of -1 in the Max Delta is getting colored the Range 3 Down Color makes sense, since this is the largest negative value.
What is odd is that we are getting the +1 values colored the Range 3 Up Color for the Min Delta.
The following is an image of what we see where we changed the Range 3 Up/Down colors to stand out (yellow and blue). We really do not know why the Min Delta is not coloring in the image you provided - it should be - unless there is another value somewhere that is greater than 1.
https://www.sierrachart.com/image.php?Image=1671743526658.png
[2022-12-22 21:28:09]
Is there a way to have custom colours for these specific rows without affecting the other rows? I would prefer not to have any coloured background when it's showing -1 or +1 for the Max/Min Delta rows specifically.
[2022-12-22 22:03:39]
There is not a way to do what you are wanting.
